Sponsored by: Innova
Which Sub?
Old May 13, 2004 | 04:42 PM
2004lariat's Avatar
2004lariat
Which Sub?
Ok - I have narrowed it down to 2 subs. It will either be a MTX 5510-44 or a JL 10W3v2-D4 Both are 10" with Dual 4 ohm Coils
Which one do you think will work best in a 2004 Lariat Screw?
Old May 13, 2004 | 05:46 PM
cangim's Avatar
cangim
Both subs are great, as far as what will work best, I'd go with the which ever sub will work the best in the box you have/or will be getting. Match sub to the box is always the best bet.
Mike
Old May 13, 2004 | 11:57 PM
the dude's Avatar
the dude
i agree... depends on what type of box you will have. large, ported, and boomy or small, sealed, an tight. check the specs on each sub and see what type of enclosure they work best with. also, depends on what amp you will use and how much power it has. i think a ported box is a little more efficient than a small sealed box, but is a bit lacking on the sound quality side.
Old May 14, 2004 | 08:02 AM
dzervit's Avatar
dzervit
I'm waiting for the JL Audio stealthbox... release is still TBD. Once I got my first JL, I've never purchased anything else since. The best bass reproduction, period. Just don't put it in a junk box. The best sub in the world can't overcome a poor enclosure!
Old May 14, 2004 | 08:03 AM
2004lariat's Avatar
2004lariat
I will be using a MTX251 class D amp to run the sub at 2 ohms (250 watts) in a custom build sealed box.
Old May 14, 2004 | 11:24 AM
1979_F100_302's Avatar
1979_F100_302
running two 4ohm DVC's are going to place a 1ohm load on your amp. You should check your manual that came with your amp to see if it is 1ohm stable because if it is only 2ohm stable running those subs will destroy your amp. If it doesnt and you still want to use that amp look into running 3 4ohm single voice coil subs.
Old May 17, 2004 | 12:08 AM
2004lariat's Avatar
2004lariat
I will only be using one DVC 10" 4 ohm sub. It will be wired in parrell which will be a 2 ohm load. Would it not?
Old May 17, 2004 | 09:18 PM
1979_F100_302
yes it would be.
buffalocomputer
Escape & Escape Hybrid
Jun 12, 2016 08:38 AM
wetbiker
Vehicles for Sale
Aug 16, 2015 09:12 PM
ZEALOUS_DRAGON
Mar 29, 2012 03:25 AM
rustynuts
Mar 6, 2006 01:29 AM
