multi-fuction switch
Old May 12, 2004 | 09:00 PM
Gemini19th81's Avatar
Gemini19th81
does anyone know where the multi-fuction switch is located, don't want to rip apart the steering column if its somewhere else. 96 explorer limited.
Thanks.
Old May 12, 2004 | 09:21 PM
HomerWinzlow's Avatar
HomerWinzlow
Yep, that little turnsignal lever you use everyday is part of it. You dont have to rip apart the columb though, just remove the trim covers far enough to remove the two screws holding the switch assembly to the columb.
