I tried using the search, but came up with nothing positive, so a question...
Is there a Ford, or aftermarket auxiliary high idle for the '96 Powerstroke? Or should I try to figure out how to make something myself? I have used the Semi Trucks pole on the pedal idea, but it is not much use..
Wm
F450 White with Grey interior Crew Cab. Banks Turbo, Intercooler and Exhuast,
Power pack Chip, shift kit, Auxiliary transmission, electronic enhanced transmission control,
16 forward and 4 reverse ratios. 340hp 660ft lb 4 wheel drive, 4.10 gears, 12,ooo# winch
Ford sells one that pretty handy but high priced, they call it a "Auxiliary Idle Control" or AIC for short. It can also be used for a PTO control. Do a search in this forum and you'll find references to it.
Thank you, Powerstroker, for that information, it looks like a good item. However, I read your post too late - I have already ordered the Ford item, and have to stand by that.. but, the next powerstroke I get will have the cheaper one in.. (I hope to buy another less utility related truck sometime this year)
Wm
'96 F450 White with Grey interior Crew Cab. Banks Turbo, Intercooler and Exhuast,
Providence intervened, and I could not get the Ford part, so I am ordering the one you suggested, Powerstroker250.. Thank you again.
Wm
