302 Distributor Question
Old May 12, 2004 | 03:22 PM
Woodsman_30350's Avatar
Woodsman_30350
I purchased a 302 with C4 tranny out of a 1977 Lincoln Versailles. The distributor has a red cap and an electronic pickup inside instead of conventional points. There are two wires with a connector coming from the distributor. Can anyone explain what setup I have? Do I need a ignition module (if so the old one must have stayed at the salvage yard). It appears to have a conventional coil but I must say I am somewhat lost. I was planning to install a Edelbrock non-egr Performer manifold and Holley 4 barrel carb in place of the exisiting 2 barrel one and a conventional distributor. I want to make this setup as simple as possible for installation into a 50 F-1.
Any comments will be appreciated.
