Front diff noise - Dana 44
Old May 12, 2004 | 12:16 AM
capnkirk13's Avatar
capnkirk13
I am replacing the drivers front wheel bearing on my '74 F250 4x4 w/Dana 44. When I turn the wheel assembly I hear a bad grinding/clunking noise(hard to explain noises but I'm pretty sure it shouldn't sound like this) coming from the differential. I just bought the truck this month and between the headers and fist-sized hole in one muffler, I didn't hear the noise. This wheel bearing I'm replacing is EXTREMELY bad so I'm in it this far, should I go for rebuilding diff or is a new 44 the better route. Thanx in advance.
Old May 12, 2004 | 01:19 AM
yukon_bluenose's Avatar
yukon_bluenose
Thumbs up front diff noise
change both sets of wheel bearings ,axles r out anyway check splines for damage if damaged pull diff cover and checkfor other damage if none ur good to go..... i own '79 f250 dana 44 front /rear,390 t18 tranny and np205 transferw/t18 tranny.................... yukonbluenose
Old May 12, 2004 | 09:56 AM
peteyg's Avatar
peteyg
If it's making bad noise, pulling the diff cover will reveal the issue. Not a bad idea to do anyway to change the fluids. That's the FIRST thing I do when I get a new (to me) old vehicle. Grinding noises are usually caused by burnt bearings, and the clunk could be the carrier floating around on the worn bearing.
jimmyz469
Dec 6, 2014 09:56 AM
FlaresideF150
Jan 8, 2014 01:54 AM
mtmatzf150xlt
Feb 16, 2011 08:24 PM
