Sponsored by: Auxito
rear window question
Old May 11, 2004 | 09:06 PM
The Phenom's Avatar
The Phenom
how hard is it to take the rear window off an f150?
Old May 11, 2004 | 09:28 PM
Ultramagdan's Avatar
Ultramagdan
It's not hard - just takes a little time since you have to strip the interior. If you can turn a wrench you can do it. Are you replacing the stock window or are you trying to patch the old one?
Old May 11, 2004 | 10:00 PM
The Phenom's Avatar
The Phenom
i might be taking one of a truck at a junkyard since mine got shattered.
Old May 12, 2004 | 12:28 AM
Racerguy's Avatar
Racerguy
If you search in here you'll find some posts on replacing the window.
It would be good to practice on one at the junkyard
Old May 13, 2004 | 08:35 PM
Ultramagdan
If you are replacing the slider window be very careful when you remove it. Bending it during the removal process will crack the frame and cause a leaking window.
