Offroad & 4x4
supenshion ?
Old May 11, 2004 | 08:41 PM
94btfrdtuf's Avatar
94btfrdtuf
supenshion ?
Will a 84 bronco 4 inch skyjacker lift fit on a 94 f150. im not shure if it exsaclly and 84 but its right around that year
Old May 11, 2004 | 08:57 PM
95-F-350-4x4's Avatar
95-F-350-4x4
Is this for the kit or for the system? If it is for the system the rear springs won't work. The model # is different and the Bronco uses 2" springs and the F-150 uses 4" springs in the rear.
Link to 1994 F-150
http://www.skyjacker.com/products-se...umber=284PKS-A
Link to 1984 Bronco
Old May 11, 2004 | 09:00 PM
94btfrdtuf's Avatar
94btfrdtuf
it has lift blocks in the rear
Old May 11, 2004 | 09:24 PM
95-F-350-4x4
Ok hard to say. The "kit" for both of these year model trucks are very similar. The only difference is the blocks part number on the 4" block part # 284B for the Bronco and part # 284P for the truck. Tough to say I would call Skyjacker to be certain. Or you can just do a reverse shackle flip for the rear for 4" of lift. The rest of the kit is the same though.
Link for F-150
http://www.skyjacker.com/products-se...number=284PK-A
Link for Bronco
http://www.skyjacker.com/products-se...number=284BK-A
Old May 12, 2004 | 03:23 PM
94btfrdtuf's Avatar
94btfrdtuf
what is a reverse axle flip anyways
Old May 12, 2004 | 03:42 PM
95-F-350-4x4
It flips the rear shackle of your truck and gives you lift and more flex. You can buy a kit or you can fabricate your own hanger. Sky www.sky-manufacturing.com sells the brackets for $119.95 which gives you 4" of lift in the rear and utilizes your factory springs.
Old May 12, 2004 | 08:13 PM
rlh's Avatar
rlh
Full size Broncos have 3inch wide leaf springs in the rear. The length of the spring packs from eyebolt to eyebolt may be different on the F150 and Bronco. The TTB stuff from 1980-96 Broncos are interchangeable. Keep in mind the lift manufactures have changed designs and available options over the years, sometimes for the better and sometimes for the worse. The TTB stuff for big Broncos will work on 1980 through early 90s F150s. I think the 97 F150s are different?
