Hi fcb and welcome to the forum
The flashing OD light is like the Check Engine light except it's for the transmission.
You will have to get it scanned for codes.
Does the transmission shift ok?
[QUOTE=FCB] HEY RACERGUY FORD HAS DONE MANY SCANS HAVE REPLACED SENORS PROCESSOR SPEDO GEAR AND A REDESIGNED SPEDOGEAR NOW THEY SAY I NEED TRANSFER CASE AND DRIVE SHAFT WHAT DO YOU THINK?BUT THEY WONT GARENTEE IT WILL WORK PLUS THE WANT 2000 BUCKS TO DO IT MY TRUCK IS A 97 F150 SUPERCAB WITH ONLY 47 THOUSANDS MILES ON IT I WILL TAKE ANY SUGGETIONS ON WHAT TO DO THANKS FCB (the trannsmission shifts fine you wouldnt no anything was wrong if not for the light flashing)
Did they say what is wrong with the transfer case and driveshaft?
I've seen the speedo gear worn enough to cause an erratic speedo signal which made the OD light flash but usually a new gear will fix it.
