93 4.0L power loss/rough idle/stall while warm out
I was wondering if anyone has any ideas for me beacuse i'm stumped. The following problem happens to my 93 Explorer 4.0L when its warm outside. but not when it is cold. it runs great in the winter but when it gets above 70 outside it will run REALLY rough and stall when i drop the revs below 2000. i have changed the following to brand new: spark plugs, wire, coil pack, TPS, crank case sensor, O2 sensors (both), and MAF.
The check engine light is on and the codes say that both O2 sensors are running both rich and lean! even after clearing the codes i get the same codes back. and this only happens when its warm outside. any help would be greatly appreciated.
It's possible. IAT and ECT are pretty easy to test, as they are simple thermistors. Measure the voltage drop across the sensor and then look up the temperature on this chart: www.xmission.com/~vondm/fordtempsensor.txt But I would still start with a fuel pressure test.
Did you ever resolve this problem? I have a 92 that is exhibiting the same symptoms but doesn't give me any codes except 111 (no error found). I have run codes several times. Truck also pings under load.
I have recently replaced many parts to cure other problems or as routine maintenance, including: fuel pump assembly, plugs, wires, MAF, IAC. Cleaning the intake didn't help either. Truck has 270K on it, but engine only has 55K.
IAT for me perhaps?
IAT for me perhaps?
MCGA
1997-2006 Expedition & Navigator
07-23-2012 10:21 PM
rad1026
01-28-2010 11:25 AM
timothy47129
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
10-13-2006 07:22 AM
