Tranny or drivetrain prob...HELP!
Old May 11, 2004 | 05:48 PM
dbuck50's Avatar
dbuck50
2 days ago I started getting a really wierd noise when I was doing about 70MPH...it was kinda like a rubbing/grinding noise that i could hear at that speed inside the cab. It came and it went and only happened at higher speeds. Yesterday it got a little worse and started happening at about 60MPH here and there. Today it is really bad and happens at anything over 30MPH. It doesn't seem to drag on the truck, but the noise is bad and I can't believe it can go very long like this...I can not only hear it, but feel it too.
It shifts fine, the tranny seems to work perfect. The only other symptom is just after I come to a stop, I feel a bang like it is hitting hard in gear--that never happened before. All gears work fine, including reverse. Tranny and transfer case fluid/filters were changed about 8K ago and both fluids look fine. I'm wondering if this is a torque converter that is going bad?
Its a 93 F150 5.0L 4X4 E40D Auto with Warn manual hubs
Thanks for any help you can give!
Old May 11, 2004 | 10:35 PM
dbuck50's Avatar
dbuck50
Maybe the transfer case?
Old May 12, 2004 | 09:11 AM
FordPerf300's Avatar
FordPerf300
Sounds like tcase to me, had the same thing happen to me, when i let off the gas on the highway i got an aweful grinding sound, and then another grinding sound when i got back on the gas. I still haven't gotten to ripping my old tcase apart to see what the damage was.
Old May 12, 2004 | 10:17 AM
kyleC9959's Avatar
kyleC9959
My transfer case went out in my last truck (and it was a chevy). It would pop out of 2 high, and into neutral, when we were on the highway going about 70mph. It was just kind of nocking before every once in a while. I don't know if yours is a tcase, but that is my experience when my t case went out. Maybe this will help, Kyle
Old May 12, 2004 | 11:10 AM
HardScrabble's Avatar
HardScrabble
Temporarily Deactivated
I would stop driving the truck until you find the problem.
Run the truck on a rack at that speed and listen with a stethoscope to pinpoint the noise.
Feel for heat after you run down the road a bit.
Look for metal in the fluids.
Old May 12, 2004 | 06:11 PM
nhenson2001's Avatar
nhenson2001
I am having a similar problem, still only happens over 62mph. Very violent and stressful sound. Sounds definitely more front end now than it did originally. I took out the front driveline to be sure it wasn't U-joints. Did you ever find the solution to your problem.
Old May 14, 2004 | 03:13 PM
dbuck50's Avatar
dbuck50
turned out my planet was completely gone, and the chain in my transfer case was bad. I'm getting the whole thing rebuilt...and having the updates to the E40D done.
tsunami23
2004 - 2008 F150
May 2, 2014 03:10 PM
bigmac83
Dec 6, 2013 06:16 PM
76f1390
1983 - 2012 Ranger & B-Series
Dec 3, 2007 08:23 AM
fire7882
17
Jan 15, 2006 12:10 PM
