Glow Plug Question?
Old Mar 5, 2002 | 08:35 AM
wiredright's Avatar
wiredright
Glow Plug Question?
I am working on a 1996 F250 PSD. The Glow plugs stopped working. I found the Control module was bad, so I replaced it. After replaceing it, I noticed the plugs now had power, but the control module stays on even after the motor is started. I thought the module would turn off after 30 seconds or so, but it don't. Does this turn off or am I missing something?
Old Mar 5, 2002 | 10:48 AM
The Diesel Dude's Avatar
The Diesel Dude
Glow Plug Question?
It is supposed to cycle off and on until the engine gets warmed up.
Old Mar 5, 2002 | 04:33 PM
wiredright's Avatar
wiredright
Glow Plug Question?
I've seen that on the earlier (94 type glow plugs) buit I wasn't sure about the 96. Also, I measured the resistance of each plug and I read 1 ohm, I was told it should be between 1 and 5. So I guess that they are fine then. Does anyone know it that is right?
Old Mar 6, 2002 | 02:55 AM
The Diesel Dude
Glow Plug Question?
Old Mar 8, 2002 | 04:00 AM
The Diesel Dude
Glow Plug Question?
The glow plugs could be burnt out and still be grounded. The best way to check them is have an assistant turn the key while you hold an ammeter across the battery cable. Each glow plug draws about 40 amps so the first time the controller cycles it should read about 320 amps, give or take 20 amps.
Old Mar 8, 2002 | 10:44 AM
curmudgeon's Avatar
curmudgeon
Post Glow Plug Question?
[updated:LAST EDITED ON 08-Mar-02 AT 11:46 AM (EST)]Joe: Thanks, as usual, for a great tip. I've been trying to get the amperage rating for 8 working glow plugs for months; the dealers are clueless, none of the tech manuals have it, and not even the local Navistar guy knew. What a forum this is!
Old Mar 8, 2002 | 11:49 AM
The Diesel Dude
Glow Plug Question?
They will only draw that amperage the first time they cycle on. As they get warmed up the amperage draw goes down. But the first time they cycle on from cold (room temprature or less) you should see full amperage.
ryanelwood
Jul 14, 2012 11:01 AM
FishyBiz
Nov 7, 2011 07:19 PM
Hotrod_ace
Jul 5, 2011 01:28 PM
klmracing
Dec 15, 2009 07:13 PM
quiethorse
Dec 7, 2004 11:00 PM
