1978 - 1996 Big Bronco
Diffs between GVWR's
Old May 11, 2004 | 04:34 PM
BootHill's Avatar
BootHill
The only difference I can find between the base 6050# GVWR and the 6300# GVWR Bronco is the addition of dual front shocks and rear stabilizer bar. How does that account for 250# more capacity?
When looking at the difference between the 6300# GVWR and the 6450# GVWR Bronco I see that the 6450 has higher capacity front springs, single HD front shocks instead of dual shocks, and the same rear stablizer bar.
The spring codes for the 6050 and 6300 is the same.
Are there other differences? If I put the 3800# front springs from a 6450# GVWR Bronco along with the shocks and rear stabilizer bar, would my 6050# GVWR truck then be 6450# GVWR, effectively, not legally?
Thanks in advance.
Old May 13, 2004 | 09:41 AM
BootHill's Avatar
BootHill
Question No one knows what goes into GVWR differences?
I am sure someone out there knows, but just hasn't read this thread yet.
Okay, how about this. What are the different Coil Spring codes for 92-96 Broncos? Do you also have the capacities?
Old May 13, 2004 | 10:36 AM
jimandmandy's Avatar
jimandmandy
Sometimes the difference is only tire size, or even legal restrictions for smog or registration fees in certain states, without a single physical difference.
In this case it may be XL-rated tires, that might have come in a package with the dual front shocks and rear stabilizer bar, vs standard load 235/75-15 tires. My F-150 4x4 (6250 GVWR) had XL tires, along with the extra front shocks and rear stabilizer bar. Mine also has the towing package, which may include some of those items.
Jim
acadianbob
Feb 22, 2022 12:19 PM
MagicMtnDan
May 9, 2017 09:46 PM
Owen Rowell
All Things Towing
Nov 11, 2016 11:28 AM
palmrose2
May 5, 2016 12:48 AM
todouble
6.4L Power Stroke Diesel
16
Jun 4, 2012 08:29 PM
