high HP IDI?
Old May 11, 2004 | 03:42 PM
RawPower's Avatar
RawPower
high HP IDI?
Anyone ever heard of a high HP and Tq 7.3L IDI?
I havent, but would like to.
easiest way seems like ATS or Banks turbo, pane, NOS if your feeling suicidal, a 4" w/ downpipe, and water injection, and possibly an intercooler (anyone make them for a 93 turboed 7.3L?)...
Anyone ever done any mods to an IDI's injectiors, or does anyone make them for it?
Old May 11, 2004 | 04:36 PM
nogo73's Avatar
nogo73
um yeah it was in a 1968 ford f150 2wd or something like that with twin turbos and the exhuast comeing straight up out the engine bay
Old May 12, 2004 | 11:12 AM
Spectramac's Avatar
Spectramac
Well, if you have a factory turbo, you already have an ATS (mostly). You just need to get a few of the Ford parts swapped out to get some HP.
Old May 12, 2004 | 02:44 PM
RawPower's Avatar
RawPower
Do they make new turbo housings to have a larger exhaust exit hole, cause the factory is tiny...
few other parts like what, injectors?
Old May 13, 2004 | 11:32 PM
Spectramac's Avatar
Spectramac
ATS will sell you both exhaust housings and a 3" exhaust kit. Then you can turn up the wastegate and injection pump. It'll move then.
Old May 13, 2004 | 11:56 PM
351M's Avatar
351M
I have heard of an 83 6.9 with twin turbos. It passed everything on the highway loaded or not till the heads blew. 7.3 is supposed to be able to handle that kinda boost though so it is a thought.
Old May 14, 2004 | 01:34 PM
nogo73's Avatar
nogo73
the idis can't handle 30 psi no way are they going to take 50+. 22.5:1 compression is just to high to have large amounts of boost. the most I heard of saftley (source: ATS) 17 psi they said it must be intercooled to do it.
Old May 14, 2004 | 09:03 PM
Spectramac's Avatar
Spectramac
I've run almost 18 before on mine, not for long though.
Old May 18, 2004 | 04:13 PM
n stephens's Avatar
n stephens
does anyone have any ideas how to keep the belts from jumping on a91 7.3 diesel
Old May 18, 2004 | 04:57 PM
nogo73's Avatar
nogo73
get the 94 belt tensioner with a small shock looks werid but it works it cost about $150 through ford.
