Tranny Question
Old May 11, 2004 | 02:52 PM
ROD GETTY's Avatar
ROD GETTY
Question Tranny Question
I heard a rumor the other day that a 4 speed O.D. tranny from a Granada will bolt to my 52 F1 Flatty, anyone have experience with this one.
Old May 11, 2004 | 04:36 PM
GreatNorthWoods's Avatar
GreatNorthWoods
Haven't heard that one. I know there are adapters you can get to bolt a C4 to a flathead, so if an AOD is the same pattern (think it might be but not totally sure), then you might be able to use the adapter to bolt one on...
Vern
Old May 12, 2004 | 02:42 AM
BlueOvalRage's Avatar
BlueOvalRage
It's not gonna happen. The C4 3-speed has a removable bellhousing which allows for the adapter kit. The AOD found in the Grenada, etc. has an integral bellhousing. Doesn't lend itself well to being attached to anything but a small block Ford.
Old May 12, 2004 | 03:28 AM
angus's Avatar
angus
You don't mean a 4 speed manual transmission, where 4th is actually overdrive?
Old May 12, 2004 | 05:57 AM
ROD GETTY's Avatar
ROD GETTY
Sorry guys I should have explained it a little better, Angus hit the nail on the head. It is actually a three speed manual with a fourth as overdrive, I wasn't thinking AOD.
