Master cylinder?
Old May 11, 2004 | 12:01 PM
BlueTorpedo85's Avatar
BlueTorpedo85
Master cylinder?
My dads 86 dump (6.9l) has just been put back on the road. Yesterday he called and said his brake pedal went all the way to the floor and it took constant pumping to get back pressure. He checked his master cylinder which was a little low on fluid, and topped it off, but it still needed to be pumped to build back pressure. I'm not home to check it, but I'm guessing this is a master cylinder. Anyone have any other opinions?
Old May 11, 2004 | 05:09 PM
Al_V's Avatar
Al_V
Been there, if you still have fluid and no brakes, replace the master cylinder.
Most, if not ALL other brake system (non ABS) problems will lose fluid fast.
