2100 to 4100
Old May 11, 2004 | 09:10 AM
mallardgreen's Avatar
mallardgreen
2100 to 4100
Aside from different intake, are there any problems switching from Autolite 2100 to 4100 carburetor on a 360 with an automatic? Will throttle linkage hook up the same? Is air cleaner assembly the same?
Thanks for any advice.
Old May 11, 2004 | 05:42 PM
Torque1st's Avatar
Torque1st
Posting Legend
Moved to proper forum.
Old May 11, 2004 | 11:03 PM
LxMan1's Avatar
LxMan1
It should hook up depending on which type of kickdown lever that your truck uses.
If it is the rod the runs from the carb to the tranny, you may have to slightly bend it because the carb linkage may be just a little bit farther away from the firewall than on the 2bbl, but not much.
66v8baby
Jun 21, 2018 09:32 AM
jwcopeland
Jan 25, 2017 06:41 PM
LARIAT 85
Aug 11, 2011 07:54 PM
gusso
Mar 9, 2010 02:51 PM
ClatonK
Jan 6, 2004 06:08 PM
