95 150 fuel problem
Old May 11, 2004 | 12:07 AM
stavros's Avatar
stavros
95 150 fuel problem
I ran out of gas on the front tank, first time ever.
After I Filled the front tank and the engine would not run on the front tank at all. On the rear fine but as soon as its clicked to front it dies . It still pulls gas from the rear tank .
I thought these were single pump so maybe there is a filter I dont know about?
Thanks for any ideas
Old May 11, 2004 | 12:16 AM
lindsay's Avatar
lindsay
there is a pump in each tank. you may have cooked your front one by running it dry. & yes there is a filter on the inside frame rail along the front tank. it is for both pumps.
Old May 11, 2004 | 07:10 PM
stavros's Avatar
stavros
Thanks for the reply
Do you know if they are on the same fuse?
Old May 12, 2004 | 04:09 PM
lindsay's Avatar
lindsay
you can check the relays under the hood. im not sure about the fuse.
