How long before getting a chip?
2001 F-350 Lariat 4X4 Crew Cab Diesel Hypermax Chip, Pyro/Boost Gauge and 5 inch exhaust soon to come!
I waited about 10,000 miles before I installed my Banks Stinger-plus, Banks exhaust bake and Cyclone power fan on 99F350 XLT Dually Crwecab 4:10 and 90 gal aux fuel tank
>expires.If im not mistaken adding super chips voids the
>factory warranty.....NO?
No, it does not void the warranty. I can post the Superchips documentation on this, an article from Car Craft about it and the Magnuson-Moss Warranty Act. If you have an issue, its the dealer that's refusing it, but they can't void the warranty. Take it to another dealer. I also have names and phone numbers of dealers that sell Diablo and Superchips.
I just recently bought mine
>(2002,250 crew cab,4x4,w/psd)and i was very astounded the
>first time i really jumped on the pedal from a
>standstill.Got enuff power for me right out of the
>box,however do the superchips improve fuel mileage as well
>as horsepower?and is it a significant improvement or just a
>small one?Just curious.
Its a significant improvement, plus the transmission shift is SO much better! Here's what it does:
Changes the injector control pressure.
Changes the injector pulse width.
Changes the boost map (more aggressive curve).
Changes the torque map (more agreesive curve).
Increases the line pressure curve in the transmission, resulting in a progressively firmer shift.
Changes the shift points. This is controlled by mph at partial throttle and by rpm at wide open throttle.
Reduces the shift delay.
Adjusts the torque convertor lockup parameters.
With the injectory control pressure and pulse width, the curve is also changed to reduce or remove the flat spot common in Powerstrokes.
