Sponsored by: Auxito
Steering Wheel Popping
Old May 10, 2004 | 10:25 PM
sjenkins's Avatar
sjenkins
97 F150 4x4 4.6l 5 spd. I am noticing a "popping" feel in the the steering wheel at lower "under 40" speeds. I happen both when just turning the wheel side to side and also when is it on the stops. The power steering level is fine. I was just wondering if any of you have had this problem and if so how you fixed it. Any help would be greatly appriciated.
Thanks,
SJ
Old May 11, 2004 | 08:24 AM
Racerguy's Avatar
Racerguy
I would start by checking, or having checked, the ball joints and tie rod ends. You may have 1 worn out. Worn out tie rod ends can eventually break and you'll have no steering......not a good thing.
Old May 20, 2004 | 07:11 PM
cnolin's Avatar
cnolin
i had a 90 with the same problem was the ujoints
Gangley
Sep 26, 2013 08:42 AM
blueline970
Sep 18, 2013 12:30 AM
CR125Honda
18
May 3, 2013 08:37 PM
volthause
Dec 17, 2012 08:35 AM
Rocksetter
Jan 20, 2010 01:13 PM
