'85 460 snapping and popping
Old May 10, 2004 | 12:30 PM
Darkraven's Avatar
Darkraven
Hello all,
I have an 85 F250 with a carb 460. My question is when I use the engine compression to slow down (downshifting) I get minor backfire or at least that is what it sounds like from the tailpipe. It can be mild or it can really pop, depending on how much of a load I am putting on the engine.
I know that my vacuum advance on my distributor isn't working, and I have the vacuum ports plugged right now until I can get it fixed. I checked the time and it is 10-12 BTDC. Is there anything I can do to fix or reduce this?
Thanks
Old May 10, 2004 | 09:29 PM
neverenough's Avatar
neverenough
Sounds like your valve seats are sinking, common problem on Ford motors. Do a cylinder leak down test, I bet you will find the exhaust valves leaking. Running rich on the carb could be causing the exhaust to fill with unburnt gas too. An exhaust leak could also be causing the problem.
santeeford
Jul 26, 2013 08:29 PM
fordlovinfarmer
May 6, 2009 01:56 AM
drmgoat
18
Nov 11, 2008 10:35 AM
85CREWCAB
Apr 18, 2004 05:17 PM
