Tried search but no luck, auto climate control temp question
May be a moot point but the auto climate control in the front cabin runs quite cold compared to the setting. For example I usually keep it set on 75 to 78 degrees F to maintain a comfortable level in the cabin (70 to 72 degrees F). It appears if the internal sensor(s) is reading 5 degrees higher. Is this normal for the Expy? My Audi had a way to read out faults from the AutoClimate control directly on the control display. Is this possible on the ford?
If it reads more than plus or minus 2 degrees off while driving (not just while idling or after re-starting), all you can do is try a new sensor.
Theoretically, there are things you can do to modify the readings from these sensors if one knew the exact type Ford is using, but nobody's telling, and nobody, to my knowledge, thinks its worth his time to figure it out.
PS: ATC settings don't feel the same as the thermostat in your home. You've got a lot more sun exposure, for example, and the engineers design for that. I have had many vehicles with ATC and I always find that a 72 setting feels too cold to me. They would have many more complaints if the reverse happened, so they may overcompensate. And, yes, the panel will read out faults, but I don't believe it can tell if a sensor is off by 5 degrees.
