Quick clarification
Old May 9, 2004 | 05:09 PM
fmc400's Avatar
fmc400
MSEE
Quick clarification
I've heard two different answers from my buddies...when I start my 400 in the morning it backfires out the carb. Is that because my choke pulldown is too far open or too far closed?
A side note--to let my throttle solenoid extend, I have to have the pedal down while I start the motor. Is that a contributor to the backfiring?
Thanks
Old May 9, 2004 | 07:00 PM
Torque1st's Avatar
Torque1st
Posting Legend
Moved to proper forum.
You only need to bump the throttle linkage to set the choke. The idle solenoid does not activate until the key is in the run position.
Old May 10, 2004 | 12:10 AM
fmc400's Avatar
fmc400
MSEE
On mine, I have to bump the throttle to give room for the throttle solenoid's arm to extend, otherwise it will hit the throttle lever and can't extend to raise the idle. If I don't bump the gas, the idle lever rests on the standard idle screw and the idle is too low. Is it possible that doing that during startup causes a backfire?
If not, is my choke plate too far open or too shut?
Thanks
