I have a 460 in my Jet Boat but there is one small problem, to drain the oil you either have to suck it out with a vacuum pump or dump it in the bilge and drain it out of the boat. Well I don't like either of these options so I put a ball valve on my 10 qt. Milodon marine pan. Now I just plug a hose onto the barb, open the ball valve and run it right out of the boat drain. If you look close where the assembly meets the oil pan I had to drill and deck a quarter (25 cents) to come up with a good bushing, gotta improvise when the hardware stores are closed.
Now lemme see if I can figure out how to upload pics on this sucker.....
hmmm.....that is a good question, how do you upload pics on this board? I can't seem to figure it out ????
