Sponsored by: Auxito
Truck engine shake
Old May 8, 2004 | 06:58 PM
piker's Avatar
piker
Truck engine shake.
I have a 98 f-150 v6 4.6L. Lately its been acting up. While driving, truck starts shaking, engine light comes on and I pull over, shut truck off and restart. Once I restart shaking stops still notice hesitation but runs ok. Code for the check engine light says cyclinders 1 and 6 misfire. I 've put new coil pack, two oxygen sensors and 7 hrs labor by local gargage. I've disconnected ERG ? as a test and this didn't work. Does anybody have any clues
Old May 8, 2004 | 07:41 PM
WhëëlMå1's Avatar
WhëëlMå1
Welcome to FTE piker! This question belongs in the 1997-2003 F-150 forum . I am sure someone there can give you an answer.
Rich
Old May 9, 2004 | 12:43 AM
Torque1st's Avatar
Torque1st
Posting Legend
Hello piker!
Moved to proper forum and a descriptive title added..
Old May 9, 2004 | 01:08 PM
LxMan1's Avatar
LxMan1
I would put new plugs and wires on it before I went any farther. I would also recommend using Motorcraft parts. They cost a little more, but they are a much better quality and will last a lot longer than the cheaper aftermarket stuff.
Jimmy
Old May 9, 2004 | 02:29 PM
Tom's Avatar
Tom
On something like that, when you have cylinder misfires, the FIRST thing you do is CHANGE THE SPARK PLUGS. A fouled plug is the easiest, cheapest, and most common cause of a misfire.
To check if the ignition system is working, pull the #1 spark plug and hold it about 1/4 inch from the engine block and have someone else crank the engine. If you see a spark, the ignition system is working. If not, then start with wires before replacing the coil pack.
If you are getting a spark, or that doesn't work, then you move on to other things. Fuel injection would be my next bet. Try some fuel injector cleaner in the tank and see if it fixes it. Beyond that, have the shop check and make sure the injectors are functioning properly.
Hope this helps!
New F150 Guy
EcoBoost (all engine sizes)
154
Jan 19, 2017 04:00 PM
Bigd1975
2004 - 2008 F150
Sep 24, 2015 11:29 AM
wondrn
Jul 22, 2014 06:40 AM
alabamawolverine
1997 - 2003 F150
Jul 21, 2014 09:00 AM
