Coolant Leak
Old May 8, 2004 | 02:20 PM
mightypizu's Avatar
mightypizu
Coolant Leak
1996 EXP 4.0, 100,000 miles
I recently drove cross-country and made it 3/4 of the way before I stopped for lunch, came back out, and noticed a huge puddle of coolant underneath the front end. Looked like it was leaking from the bottom corner, drivers side of the engine, looks like a gasket problem but not sure which one. I see what looks like to be the "freeze plug" but that doesn't appear to be leaking. Also, it doesn't appear to be leaking internally. Anyway, I used Aluma-Seal as a quick fix and made it the rest of the way, as a matter of fact, it hasn't leaked since and the coolant has been at normal levels. Any ideas? Should I still be concerned even though it stopped leaking? Also, what do freeze plugs do?
Thanks in advance.
Old May 9, 2004 | 12:05 AM
c96drumm's Avatar
c96drumm
Difficult to find the leak after it stopped. Freeze plugs are supposed to pop out if the coolant freezes and hopefully prevent block damage.
fishfreak101
Feb 10, 2017 04:27 PM
stootch
2004 - 2008 F150
Jul 12, 2015 03:35 PM
r59
15
Jan 13, 2013 10:40 AM
Killer*Mule
Sep 12, 2004 09:11 AM
bluesky636
May 5, 2004 10:58 AM
