2001 Rough Starting
Old Apr 8, 2002 | 04:44 PM
Ari's Avatar
Ari
2001 Rough Starting
I just bought a used 2001 F250 7.3PS (16K mi). At the morning start (70F) it will run rough for about 5 seconds. Is this normal?
Old Apr 8, 2002 | 05:55 PM
z1express's Avatar
z1express
2001 Rough Starting
No this is not normal,but it does happen. Have you worked on the truck at all,did this just start happening or has it done this since you bought it. It may be a problem with the high pressure oil system. It will do this if it is really low on oil or wrong type of oil. or you could have a fuel problem. Are there any check engine lights on. Could have bad sensor in the system.
Old Apr 9, 2002 | 10:34 PM
Ari's Avatar
Ari
2001 Rough Starting
No, I have not worked on the engine. Look's like I will have to call on warranty. Thanks for the advice!
Old Apr 10, 2002 | 08:07 PM
wolfmanagh's Avatar
wolfmanagh
2001 Rough Starting
