duals or singles
Old May 8, 2004 | 06:21 AM
04superduty's Avatar
04superduty
duals or singles
For those have towed what are the benefits to duals vs singles. Like a dual tandem set up verses a tri axle? I know a few, a tri axle isnt the best for sharp turns and with the dual tandem setup you have 2 more tires to worry about. But what else is there? And Mr Tim Lamkin, i think i remember you having a tri axle trailer and wonder would you buy it over again?Pros cons etc. thanks for any and all answers.
Old May 8, 2004 | 10:18 AM
1991fseries's Avatar
1991fseries
the more axles the more wieght the trailer can handle has a rule of thumb
Old May 8, 2004 | 11:25 AM
04superduty
with most tri axle setups i have seen each axle can carry 7000 lbs for a total of 21000 gvw for the trailer. Most tandum duals carry 10000 per axle for a total fo 20000 gvw for the trailer. I am wonder about stability, tire wear or any other pros or cons. The tri axles are generally cheaper due to cheaper axles.
Old May 8, 2004 | 04:42 PM
johnsdiesel's Avatar
johnsdiesel
The tires won't last as long on a tri-axle as they would on a tandem axle because of the drag when turning. Not only that, you have to buy 6 new tires instead of 4. If you can find a tandem axle well within the limits of what you want to do I would go that route. Using your example, the tri-axle only gives you an additional 1K.
Old May 9, 2004 | 09:30 AM
04superduty
thanks for all the replies so far. anyone else have any more info.
Old May 9, 2004 | 10:04 AM
fellro86's Avatar
fellro86
Last time I checked, there were four tires per axle on a tandem dual, making it 8 new tires. Typically single wheel axles handle 7000 pounds per axle. Another consideration is deck hieght, depending what you want to do. You can get triple axle low decks, but cannot get dual wheel lowdecks, if this should matter. As far as general cargo hauling, highdecks are the most versatile because you don't have any obstructions, but the load sits higher, so more wind drag and higher center of gravity.
Old May 9, 2004 | 11:44 AM
johnsdiesel
Sorry, my misunderstanding. There is still more friction involved to turn 3 axles.
Old May 9, 2004 | 02:17 PM
fellro86's Avatar
fellro86
very true, not what I was getting at. Just making the point of tire number, not the fact that it will scuff the tires on sharper turns, not really that much to notice on regular highway running.Even tandem axles scuff a little on turns, and I admit that triples will scuff, but it really isn't a major problem unless you have sharp turns regularly.
Old May 9, 2004 | 08:41 PM
f350xlt460's Avatar
f350xlt460
how about brakes? Wouldnt there potetialy be 6 brakes on a tri axle and only 4 on a tandem dual?
Old May 10, 2004 | 01:54 AM
rebocardo's Avatar
rebocardo
Many trailers only have brakes on one axle.
Old May 10, 2004 | 07:09 AM
f350xlt460's Avatar
f350xlt460
i guess i have odd trailers then.
My PJ Dump trailer has brakes on both axles and my dads tandem dual tilt top has brakes on both axles.
I would have thought that a trailer capable of grossing 21k (lets say triple axle car wedge) would have more then 1 axle with brakes.
Old May 10, 2004 | 07:51 AM
fellro86's Avatar
fellro86
my triple axle horse trailer has six brakes, most tandems have both axles with brakes, the only time I have seen just one axle with brakes is on lightweight flatbeds. I can be wrong about this, but it is what I have seen.
Old May 10, 2004 | 09:51 PM
SoCalDesertRider's Avatar
SoCalDesertRider
I've seen triple axle trailers with brakes on 2 out of 3 axles and tandems with brakes on one axle, as well as tandems with brakes on both, so I guess any combination could happen.
Old May 11, 2004 | 06:59 PM
04superduty
The number of braking axles depends on how much $$ you want to spend on a trailer, and how cheap the manufacturer is. It usually only cost between 100-200 more to get brakes on the 2nd axle. Personally i want as much help stopping as i can get so i go with brakes on all axles.
