Exhaust Leak Question !
Old May 8, 2004 | 02:08 AM
Mr.Majestyk's Avatar
Mr.Majestyk
Hi Everyone. I Have A Minor Exhaust Leak On My 69f100 (which Sounds Kinda Cool Lol) . Just Wondering If I Am Hurting The Motor At All (360) If I Leave It Alone. Im Gonna Eventually Fix It But Just Curious If Im Doing Harm To The Motor At All. Thanks All Of You :-x01
Old May 8, 2004 | 07:39 AM
Ratsmoker's Avatar
Ratsmoker
Welcome to FTE!!!!
You can hurt the exhaust valve. When you have a leak air will flow both ways through it due to camshaft overlap. This will cause cold air to hit a very hot valve and over time you will get the same effect as dumping boiling water on an icy windshield in the winter. They are best to be fixed but I have seen some go for a long time (my old 360) and it didn't hurt anything.
Old May 8, 2004 | 12:03 PM
mlf72f250's Avatar
mlf72f250
Originally Posted by Ratsmoker
Welcome to FTE!!!!
Maybe, but here's my theory... Let's say the exhaust manifold gasket leaks. Because of the strongly pulsating nature of the exhaust system, it leaks both ways. Because there is excess oxygen in the port area, the incredibly hot exhaust valve could oxidize more quickly, leading to burning. That's why engines that are adjusted lean and run hard on the highway tend to burn valves.
You normally have really high velocities rushing past the valve seat (often sonic flow) when the exhaust valve opens. And because of that high velocity, you also have high rates of heat transfer. And when you have excess oxygen -- Kind of like hitting the lever on your cutting torch. My two cents...
Old May 9, 2004 | 10:39 PM
Mr.Majestyk
Thank You For Your Replies Both Of You . Looks Like I Will Fix It Sooner Than I Anticipated. You Guys Are Great Thanks :-x01
travisd
Feb 28, 2010 04:58 PM
peanut2001
Dec 28, 2005 09:37 PM
RUSTANG67
Nov 13, 2005 09:52 PM
scurbiedog
1978 - 1996 Big Bronco
Mar 17, 2005 01:36 AM
armcan
Bronco II
Dec 9, 2003 11:46 PM
