91 Explorer Vibration
Old May 8, 2004 | 12:02 AM
hiroad's Avatar
hiroad
Question 91 Explorer Vibration
My Explorer starts to vibrate/hum when it reaches a speed of 110 km/h (70 mph). I have had the tires rebalanced, no change. I have had the ujoints changed in the drive shaft, no change. Suggestions ???
Old May 8, 2004 | 01:03 AM
85e150's Avatar
85e150
Check for bent wheels, bent shaft. Try moving the shaft 1/2 turn on the diff, if you can. Drive belts and pulleys? Does it vibrate if you run the motor up in Park or neutral? Tires coming apart and you can't quite see it yet? Front end alignment? Front end connections all good? Radius arm bushings good? Motor or trans mount?
good luck
Old May 8, 2004 | 06:41 AM
marragtop's Avatar
marragtop
Did you rotate the tires front to back?
Old May 8, 2004 | 01:21 PM
hiroad's Avatar
hiroad
Tires have 25000 km on them, rims are straight, tires where rotated when balanced.
Old May 9, 2004 | 05:43 AM
marragtop's Avatar
marragtop
DId the vibration start before or after the tires were rotated?
Old May 9, 2004 | 11:43 AM
hiroad's Avatar
hiroad
Tires & Rims are not causing my vibration..... both are running true. Vibration there before and after tire rotation.
Old May 9, 2004 | 02:54 PM
kclyki02's Avatar
kclyki02
I have a similar problem, it starts right around 65 mph. I'm on my 2nd set of tires, everything checks out ok, but it still does it and has for quite a few years.
