Internal transmission cooler
Old May 7, 2004 | 08:48 PM
kurthb's Avatar
kurthb
Why does Ford pump tranny fluid trough the radiator cooler if the vehicle has a external cooler? You would think that the transmission would absorb heat from the radiator, no?
I am thinking about bypassing the internal coolar and running with just the external, at least for the summer towing season. I could understand in the winter to get the transmission to a "working temp faster"
Does anyone know what the avg coolant temp is that is flowing by the cooler, I guess on a hot day it would be about 150.
Comments?
Old May 7, 2004 | 09:47 PM
thelonerangerxlt's Avatar
thelonerangerxlt
Kurthb, 150* is probably a good guess, since the ATF cooler is always on the coolest side of the radiator (in a crossflow design). The ATF cooler is also more efficient because it's liquid to liquid, rather than air to liquid. I would keep the factory radiator cooler and add an external cooler if needed.
While under my Explorer at the last oil change, I got to thinking how close the catalytic converter was to the transmission. Since the cat can put out up to 1200*F, the transmission had to be soaking up a lot of radiated heat. I then installed a piece of galvanized sheet steel between the trans and cat to act as a heat shield. I feel this is cooling off the ATF a bit, but since I don't have a temp gauge on the trans, can't say for sure.....
Old May 8, 2004 | 01:20 AM
85e150's Avatar
85e150
Use of both coolers is the standard install. You don't want that oil too cold.
Old May 8, 2004 | 07:01 AM
kurthb's Avatar
kurthb
While towing the other weekend, 85 ambient temp...
IN OD cruising along the freeway at 65 the transmission temp was 170-175.
Out if OD where there was a moderate grade 180-185
Climbing a good grade in 2nd 185 to 190
stop and go crawling in traffic nothing less than 187
This was monitored by a OBD-II scanner, the tranny temp sensor is right in the pan.
I would like to bring the temps down to about 150 while towing.
From what I have heard, the transmission can't run too cool (within reason)
Old May 9, 2004 | 05:54 PM
85e150's Avatar
85e150
The problem with straight cooler comes at light loads in really cold weather--then it will be too cold. You could put in a valve, I guess. The lines are easy to get to.
Macs1964F100
Jul 23, 2014 01:39 AM
johaner78
15
Jul 31, 2012 06:37 PM
82f3504x4
May 12, 2008 06:25 PM
53fatfndr
Jun 22, 2005 08:41 PM
53fatfndr
Aug 7, 2004 03:04 PM
