1992 transmission problem
Old May 7, 2004 | 05:22 PM
tds566's Avatar
tds566
have a 1992 ford explorer transmission problem when shifter is in reg drive works fine when shifter is is over drive position engine changes a little but no drive
Old May 7, 2004 | 07:20 PM
Opera House Works's Avatar
Opera House Works
I assume you are saying that there is little rpm change at highway speeds between D and OD. You are also taching well over 3K at 65. I've had both problems, stripped star washer and weld break on the OD planetary. I don't know why I even mention it, but the OD section in this transmission is really easy to fix for a neophite. That is if you don't mind pulling a transmission.
Old May 7, 2004 | 07:46 PM
tds566's Avatar
tds566
the problem is when you shift to overdrive position on shifter at stand still taking off there is nothing no go but if you put shifter in next drive position it goes fine.
Transam461
Sep 10, 2016 12:58 PM
Hall599
Jan 27, 2016 08:44 PM
zenish
Aerostar
Sep 22, 2015 02:55 PM
Ford Tempo Fan
Jul 19, 2015 10:40 PM
norfolknova
Jun 17, 2015 08:06 PM
