Sponsored by: Real Truck
Popping Sound
Old May 7, 2004 | 05:03 PM
FATBOY93's Avatar
FATBOY93
Popping Sound
I Have A 99 250, 6spd, When I Am Driving And Apply The Brakes I Here A Popping Sound From Under The Truck, In Either The Driveline Or Susp. Truck Has 56k On It And Runs Great. No Other Problems Accept For This . Thanks
Old May 7, 2004 | 05:10 PM
Yeti's Avatar
Yeti
What's your question???
Some things to check, shocks, swaybar links, slip joint on the driveshafts, cracked springs, etc....
Old May 10, 2004 | 10:54 PM
Bverwer's Avatar
Bverwer
I have the same problem and have had it fixed once. If you look between the springs, you will find some teflon bushings, they are bad. The problem is, the parts are about $30.00 and the dealer charges ~$150.00 per side. There are other postings on this site that shows direction on how to change them. I bought the parts, just need to install them
