rear end repair
Old Aug 7, 2000 | 10:17 AM
deleontow's Avatar
deleontow
rear end repair
Old Dec 15, 2001 | 11:32 AM
uncleive's Avatar
uncleive
Post rear end repair
I have a '96 F350. We pull a 5th wheel weighing around 13,000 lbs.
Near the East Coast, we had a pinion seal replaced. The seal alone, no other parts.
By the time we reached the West Coast, we head a whining noise in rear end. A Ford truck repair service found bearing races tornup.
Their comment was the crush sleeve should have been replaced with the new pinion seal. The truck dealer found minimal lash and almost zero yoke drag. An expensive repair followed.
The East coast repair facility said if the crush sleeve was a factor, the rear end would have failed long before reaching the West coast.
Opinions?
Old Dec 16, 2001 | 11:07 PM
redneckdieselmechanic's Avatar
rear end repair
The only reason i can think of for it tearin up like that is from bad oiling. And you said the pinion seal went out? probably the cause of bad oiling.
Old Dec 16, 2001 | 11:58 PM
uncleive's Avatar
uncleive
rear end repair
Thanks for the input on the rear end. The pinion seal was replaced when we noticed oil slinging underneath. It was caught before it got too low.
What I'm trying to figure out is if by replacing the pinion seal with a new crush sleeve, can that cause the lash to tighten up and burn up the bearings?
Old Apr 19, 2002 | 09:07 PM
BracketBird's Avatar
BracketBird
rear end repair
you can change pinion seals all day long without changing the crush collar. the shop who did the work must have tightened down the nut way to tight.
