D0VE-A or D0VE-C
Old May 6, 2004 | 11:03 PM
jj292's Avatar
jj292
D0VE-A or D0VE-C
I recently aquired a set of D0VE-A heads. I wanted to find out about them so I started to search these forumsa and the net. All the information I found mentioned almost exclusivly the D0VE-C heads. What is the difference between these two heads? And can anyone give me the specs on the ones I got (combustion chamber size, valve size, CR, etc.)?
Thanx, JJ
Old May 26, 2004 | 10:32 PM
jj292's Avatar
jj292
any ideas guys?
I would like to know what I am getting into
Specificaly wheather or not parts marketed for D0VE-C heads will work with the ones I have. Or if As are in some way inferior to the Cs.
Thanx JJ
Old May 27, 2004 | 02:48 AM
Superdave's Avatar
Superdave
To the best of my knowledge, there is no difference in them, performance wise anyway.
Old May 27, 2004 | 08:18 AM
neverenough's Avatar
neverenough
The suffix is just the revision. Minor changes were made between the C8VE and D0VE-C heads. The first major change was in the D2VE heads. There were performance heads made during the C8VE-D0VE run, but they are different codes, and a whole other story.
Old May 27, 2004 | 03:05 PM
There Goes The Neighborhood's Avatar
The suffix change is jsut to note that the Thermactor passage was enlarged. Everything marketed for C8-D0 will work.
Monsterford34
Oct 8, 2013 06:33 PM
WVU
Mar 5, 2012 11:12 AM
highoctane74
Apr 22, 2009 01:24 PM
Icicle
Mar 24, 2004 05:57 PM
Ford4X4
May 4, 2003 06:50 PM
