highway speeds without overdrive?
Old May 6, 2004 | 05:24 PM
Nate S's Avatar
Nate S
so are highway speeds attainable (comfortably) without overdrive? (im using a '48 flathead V8)
if not, what's the highest attainable speed....?
Old May 7, 2004 | 07:52 AM
mtflat's Avatar
mtflat
Totally depends on your rear end gearing without OD in any 1:1 tranny.
Stock rear in most of these old trucks is upper 3's to mid 4's - engine will be wrung out - 3500 rpms between 50 and 65 mph. If you run a more sustainable 2500 rpms you're looking at 45-55
The engines are tough - guys use blowers to push them around 6K, but any sustained rpms above 2500 and my tranny starts throwing bear lube out around the shift tower.
Old May 7, 2004 | 10:12 AM
46fordtruck's Avatar
46fordtruck
The stock rear gear is usually about 3.78, good for take off, bad for top end speed. My '46, with a '50 flathead 6 cylinder, stock 3 spd, and orignal 3.78 rear gear was able to do about 60-65 down the freeway, but you could tell the engine was about at it's limit as far as RPM's go. Expect to travel in the right lane most of the time, these trucks were not built for top speed. Of course, another thing to consider...how safely can you stop in an emergency situation with the stock brakes from '60?
Old May 7, 2004 | 11:42 PM
Nate S's Avatar
Nate S
i have power assist brakes . however, its good to know that 60 mph is possible. i wasnt looking to go fast, mainly i was hoping to just be able to travel on the highway at all, haha...
Old May 14, 2004 | 12:35 AM
JSMConstruction's Avatar
JSMConstruction
Exclamation
3.78 gear's are you nut's?? there prolly more like 4.88's or 5.13's well thats what they used in thr 60's and 70's all my trucks with stock tires ran60mph 3500rpm they now run 67mph at 3100rpm with some nice tall tires...
i would guess back then they had high4's to mid 5s
like 4.56-5.45's.... but then again they prolly had smaller tires so the 3.78's reved just as hard as the 4.88's...
Old May 14, 2004 | 10:23 AM
46fordtruck
No, I am not nuts, stock gearing on a half ton was 3.78, with 3.54 and 4.11 an option. I believe Nate's truck is a half ton, so my post is correct about gearing. Yes bigger trucks (1.5 ton and up) had gearing of 6.67 standard, with 5.14 and 5.83 as options, however we are talking about a 1/2 ton here.
Old May 14, 2004 | 12:57 PM
JSMConstruction
OH My bad i was lthinking of some thing else sorry i didn't know it was a 1/2ton some how i thought it was 1.5 ton dump truck...My bad sorry sorry.....
