Short shifting 6.0 auto.
whoa whoa whoa so what you are tryin to get me to believe is that say you have an F350 with the bed loaded down to max and you're pulling a trailer. You know enough to put a load on the drivetrain on accelleration you the trans will skip shift?? either 2nd or 4th? Whichever it wants at the time? Where did you hear about the 6 speed tranny?
The TorqShift has a six-gear ratio capability, with electronics control by a power train control module (PCM) that provides a different combination of shifts below or above software-calibrated temperature.
Shifts have 1-2-3-4-6 pattern below 17c
Shifts have a 1-2-3-5-6 pattern above 14c
Want or need the ratios?
My 250 CC Fx4 Lariat will damn near smoke the tires from a dead stop? Were your trucks laying black before the flash with no power adders??
mine has never even come close to smoking the tires its a dog off the line until the turbo kicks in 10 ft down the road
Originally Posted by PeteJa
I talked the Customer Service Rep. and she all but told me to take it to arbitration. They are buying back trucks with the problems mine has. I just might try it.
yes i agree they are very quick to get you to jump into arbitration they wanted me to after the 2nd trip in to fix the fumes in the cab problem
#28
Yeah that's right! Darn near smoke the tires...And if there is a hint of moisture on the road in the morning and I'm running late....wheel hop lots of wheel hop. I'm in the process of custom fabbing a set of chrom-moly tube traction bars on some 7/8 heims with a buddy of mine to take care of that problem. If it hops like that now I could only imagine what it'll be like with say a superchips programmer set to 150 horse!
