Putting F250 rear Suspention on F150
Old 05-06-2004, 10:45 AM
1newman's Avatar
1newman
1newman is offline
Question Putting F250 rear Suspention on F150
Is it possible to beef up F150 rear suspention with F250 Parts? I have air shocks already, but need more, I pull a very heavy steel trailer. Thanks.
Old 05-06-2004, 08:42 PM
SoCalDesertRider's Avatar
SoCalDesertRider
SoCalDesertRider is offline
If the springs are the same width and length, I don't see why you couldn't swap them. You may need longer U-bolts for the thicker 3/4 ton spring pack too. Another way to go is to use an add-a-leaf below the spring pack or helper spring above the spring pack or go with air bags between the spring pack and the frame. Check out www.air-lift.com for air bags. Another option is to take the truck to a spring builder and have him build you a spring pack for your trucks loaded weight. National Spring here in SanDiego does that.
One note of caution, be sure you are not overloading your 1/2 ton truck, as springs are only one of the components that come into play when hauling a heavy trailer. Weigh your trailer and your truck and look in the Ford towing manual to find your tow rating and Gross Combined Weight Rating (weight limit for the total weight of truck and trailer together). These ratings will depend on what engine, transmission, and rear axle ratio you have.
Old 05-06-2004, 09:33 PM
1newman's Avatar
1newman
1newman is offline
Thanks for the help, I didn't really even think about overloading the capacity even with no modifications.
Old 05-07-2004, 10:43 AM
teds74ford's Avatar
teds74ford
teds74ford is offline
You didn't say what years, but we were looking at this sort of thing for my friend's 95 F150. He tows a lot of heavy stuff, and we looked for junkyard springs. What we ended up doing was putting in an add a leaf, and removing the stock lift block (its a 4x4). This set it up maybe a 1/2" a higher, and really stiffened the stock pack. Since I already had the add a leaves, it didn't cost anything, but you may look at whether this would be cheaper or junkyard packs would be. He was looking at (I think) $40 a piece in the junkyard. That's $80 total, and I don't know what an add a leaf kit costs. If yours is a 2wd, the add a leaf might not be in your best interest, since it will raise the back about 2" and make it sit really high. Hope this helps, and good luck with it. Ted
Old 05-07-2004, 11:56 AM
1newman's Avatar
1newman
1newman is offline
Thanks Ted.
1tuff250
2009 - 2014 F150
11-19-2011 04:43 PM
bryanswens
11-03-2006 09:26 PM
bryanswens
11-03-2006 06:56 AM
JonR
03-13-2006 10:59 AM
amxman
1999 to 2016 Super Duty
08-03-2004 10:11 PM
Quick Reply: Putting F250 rear Suspention on F150
