Drip Rail Cancer
Old May 5, 2004 | 10:26 PM
F350 Strait's Avatar
F350 Strait
Drip Rail Cancer
I have a 79 F350 Super Cab with the some rust cancer at the bottom of the drip rail. How do I get the drip rail off the cab so I can properly clean and patch this area?
Thanks for the help!
Old May 6, 2004 | 08:42 PM
Greg 79 f150's Avatar
Greg 79 f150
If it is like my 79 F150, the rails are a part of the metal cab structure, so I could see no way to remove them. My rails were not badly rusted, just some spots, so I just sanded the spots to good metal, used Picklex 20 as a rust convertor on the pitted areas, epoxy primed, then put on a primer surfacer, then bc/cc. This worked for me because I painted my whole truck which made it easy, but if your doing just spot paint repairs, then you will have a paint blending issue to deal with of course, good luck on your project,
Old May 10, 2004 | 02:56 AM
F350 Strait
Thanks Greg,
I will be painting the truck too. I figured that at the least I would get rid of the rust, treat it, fill and paint.
