yea baby! got oil pressure
put the high vol. pump in today (4th time dropping the pan)also put the shaft in with the crown towards the dist. guy that was helping me put it in with the crown towards the pump. fired it up and had 40lbs at startup, 15 lbs hot and 12 lbs at idle in drive. but 2 things first. am going to get a better oil gauge, have a cheap no name gauge right now and i also put tranny fluid in the oil to clean it out and my oil is real thin right now.
i normally put 10w-40 in but would like to go a little thicker. would 20w-50 hurt the motor, i run it in my jeep and it does good enough. hopefully when i change the oil and filter and new gauge ill be good to go. thanks to everyone who helped me out in previous posts. thanks in advance
