[updated:LAST EDITED ON 03-May-02 AT 03:18 AM (EST)]I looked into that before i did my cummins conversion, the biggest draw back of a cat motor is that they are heavy, next the I-6's are close to too tall bottom of oil pan to top of valve covers, the 3108 will work, it came in earlier diesel 2ton and larger comercial fords . Trannys are easy but if you have 4x4 you will need to look into a divorced t-case. This way you can pick up a used motor and tranny from a wrecked 2 ton and just use a small drive line as the link.
Good Luck keep us posted if you do this conversion.
Dusty
Why Buy new when you can build and tailor it cheaper?
F-350 4x4 ext cab Short Bed Green Monster, it is now Sporting a 300HP 715lb/ft Dyno rated 5.9L 12v Cummins diesel w/ NV4500 5spd and custom NP205 ford T-case w/ rear spicer 1410 yoke, Converted to Sterling 10.5 gears w/3.73 gears using the 41 spline pinion and 1410 U-Joints, Power-Lok equipt Dana 60 front, 33's on 16x8" Outlaw II's. (Used to have)205000 miles, Mass air 460 w/ performance heads and a E40d to 5spd conversion and Doug Thorleys. Old EFI 460 @10 MPG to the 12 V @ 23.2 MPG @ 75 MPH and loving it.
My other toy is a '69 CJ-5 354 Hemi 4 spd 4.88's 32x12.50 MThompsons w/ power-lok 44 rear.
