F1 steering box adjustment??
Old 05-05-2004, 12:20 PM
blatherskite's Avatar
blatherskite
blatherskite is offline
I'm a little confused........ I was going to adjust the steering box on my F1 but it isn't as I expected. My understanding was that there is supposed to be an outer nut to loosen and then adjust the center 'bolt' in to tighten it up and then re-tighten the outer nut back down to hold it. Mine has the outer nut but no way of adjusting the 'bolt' (no slot or hex hed etc).
What am I missing (mis-understanding)???
Thanks for any help!!!
Old 05-05-2004, 01:09 PM
51dueller's Avatar
51dueller
51dueller is offline
Take the nut of the side of the box. There is a little plate that is stuck in the end of the nut. Pop it out. Put the nut on. Use a wrench on the nut and use a big screwdriver to turn the inside bolt. Put the little plate back in the nut.
MarksMedicated
10-18-2014 01:06 PM
brandon.edwards
01-31-2013 08:04 AM
Rocky Mountain F150
09-11-2012 07:55 PM
LUMBERMAN
1999 to 2016 Super Duty
07-30-2011 02:00 PM
wyazel1
04-07-2007 02:41 PM
Quick Reply: F1 steering box adjustment??
