FE stock motor mounts
Old May 5, 2004 | 12:20 PM
dffay's Avatar
dffay
OK, so next time I'll mark them......what direction do the FE motor mounts bolt up? Flange side is which direction?
Old May 5, 2004 | 07:53 PM
Ratsmoker's Avatar
Ratsmoker
What year is your truck so I can make sure I am giving you the right info. I'm not even sure if the year matters but I can look on my 1970 for you.
Old May 6, 2004 | 04:28 PM
dffay's Avatar
dffay
Actually, its a 66 390 block retrofitted into a 1953 F-100. I'm using the stock steel mounts from a 1969 F-100. I realize that the drivers side is longer than the passenger side. The steel/rubber mount with two bolt holes to the block (with the single stud) were pulled from yet another block--a 360. I'll be reusing all I can and then building up the cross piece as necessary since the lower portions are no longer sitting atop the crossmember of the 1969 twin I-beam truck. I see where there is also a right and left steel/rubber piece--those I kept marked in separate bags. But the whole caboodle will be bolted onto the engine, b/housing and T-18 tranny and slid into the truck for proper fore and aft positioning. I just need to make sure that the steel/rubber block side pieces are not inverted. Thank in advance.
Old May 10, 2004 | 09:09 PM
bob arrington's Avatar
bob arrington
on mine the offset went to the front, if i remember right the distance from the mounting face of the engine to the center of the single bolt was aprox. 13and1/2" for both sides .not 13" and not 14"
Old May 11, 2004 | 08:21 AM
dffay's Avatar
dffay
FE motor mounts
Thanks, that'll be a big help. Making things asymetrical was apparently one of Ford's better ideas.
