300 missing
Old May 5, 2004 | 12:12 PM
GR8 1's Avatar
GR8 1
300 missing
My 1986 F250 has a miss in it when it idles. It makes my enginge jerk when its cold but when its warm you can still hear the miss in the exhaust.
What causes your engine to miss? I have replaced the distributer,spark plugs, spark plug lines. I'm guessing it misses because it's worn out, but I'm thought I would write this to make shure there was nothing else I could tend to.
1986 F250 double-low 4-speed 300-I6, 1brl carb
Old May 5, 2004 | 12:16 PM
85e150's Avatar
85e150
Checked the intake bolts? My '85 works loose on #1. Starts as a off and on miss, ends up constant miss. Temperature will change it at the beginning.
Good luck.
Old May 5, 2004 | 02:30 PM
oldhalftons's Avatar
oldhalftons
ANY vac leak will make a 300 miss and run bad.
the EGR gasket and the intake vacuum tree are prime suspects anytime a 300 starts missing all of a sudden.
brandonsnider1986
Apr 15, 2013 07:19 PM
xirxious
Feb 4, 2012 06:39 AM
JWH2
Feb 22, 2008 06:40 PM
Bigmark'sblownv10
Sep 10, 2004 07:02 AM
GR8 1
Dec 13, 2003 12:30 PM
