rear end
Old May 5, 2004 | 10:04 AM
78_ford_F150's Avatar
78_ford_F150
Question rear end
would a 1974 ford 9" rear end fit in a 1978 ford
Justin
Old May 5, 2004 | 12:27 PM
dfisher1's Avatar
dfisher1
78,
There was a width change in the 9" rear end for these trucks right around 72 or 73. The old ones are wider than the later ones, i think. i got burned on a swap back in 1989. I tried to swap a a 1972 F150 entire rear end into a 76 F100. It didn't work. I ended up just swapping the forward carrier and everything is still working today.
Be careful,
KingFisher
Old May 5, 2004 | 01:00 PM
Big Orn's Avatar
Big Orn
Kingfisher is right about the change from '72 to '73, but the '74 will work just fine in the '78. Direct bolt-up.
Old May 13, 2004 | 10:03 AM
78_ford_F150
would it be worth a mini spool in the rear end or would it be nothing but trouble its for my daily driver
Old May 13, 2004 | 07:54 PM
SoCalDesertRider's Avatar
SoCalDesertRider
Spool in a pavement pounder isn't a great idea, you need some wheel speed differentiation around corners to make your tires and drivetrain last. You can use a locker though . Check out www.tractech.com and www.powertrax.com for lockers that fit the 9".
Old May 17, 2004 | 09:55 AM
78_ford_F150
kool thanx
