Cam Selection...
Old May 4, 2004 | 11:00 PM
Mud_Hunter's Avatar
Mud_Hunter
Cam Selection...
Ok ... I need help deciding what cam to run in my 390.
Im rebuilding my 390. with a 428 crank, 428 rods, 410 pistons running 10.0 - 10.5 compression. Offenhouser 4 barrel intake. Hooker headers. 36" tires. 4.10 diff
80% off road. 20 % road.
NOT a commuting truck
What do u think?
Old May 4, 2004 | 11:17 PM
fordman428's Avatar
fordman428
a crane 941 would work, i tihnk you can get away with the stock valvetrain with the 941, if you want big go with the crane 801 but that requires a beefed up valve train, kinda depends on what you are willing to spend also, im sure some of the guys like greg, sean, and dino will stop by, they all run very healthy cams but i cant remember there part #'s, good luck
Old May 5, 2004 | 08:19 AM
Mud_Hunter's Avatar
Mud_Hunter
Is the part number you listed a manufactures part number or wholesale's. I cant find anything on 941.
found it #343941 ?
Old May 5, 2004 | 06:59 PM
Ratsmoker's Avatar
Ratsmoker
You will not be running pump gas with the 941 cam and 10:1 compression with iron heads. I would suggest a bit larger cam. The 801 would be the minimum. Which heads are you running? Are you planning on porting them out a good bit? This is where cam choice becomes critical. Restricitve heads and a big cam equal poor performance throughout the RPM range. High flowing heads and a small cam equal the same thing. Which offy do you have? They made some great intakes. I wish they still were around.
To look at crane cams specs go to www.cranecams.com and look up the part number with the search box. The part number will always end in a 1. 343941 and 343801. The 343943 is the 941 cam in a kit with lifters and break-in lube.
When running high compressions on pump gas you need to pick a cam that will give you lower cylinder pressures. Increasing overlap doesn't always mean a decrease in cylinder pressure. The Lobe separation angle and advertised duration are the key elements here. The wider the LCA the less pressure. The bigger the duration the less pressure.
Old May 5, 2004 | 08:31 PM
Mud_Hunter's Avatar
Mud_Hunter
Im trying to stay stock on my heads (budget $)...build them up later...what is the minimum i will have to do to my heads for now? ...with the 801
Old May 5, 2004 | 08:41 PM
Ratsmoker's Avatar
Ratsmoker
What is the casting number on the heads?
gtex's Avatar
gtex
What would it cost to shave some off the 410 pistons? Might get the compression ratio down enough to run a milder cam. I'm thinking he wants a stump puller, not a screamer. (see 36" tires)
(I'm sure this will spark some replies from the big cam boys, to remain nameless)
Old May 5, 2004 | 09:08 PM
Mud_Hunter's Avatar
Mud_Hunter
the only time i drive my truck is to head for the hills...but i dont mind showing off alittle getting there . The casting # "E27" there is a "0" with 2 dots underneath it in front of that number. the intake is a offenhauser #"360" . Id rather spend money towards upgrading my heads instead of shaving pistons if i can help it. Or maybe a trip to the junkyard for larger heads?
Old May 6, 2004 | 09:51 PM
Mud_Hunter's Avatar
Mud_Hunter
im geussing those are not the right casting #s for the heads...looking on the internet it looks like the numbers should be longer? ..those are date #'s?
Old May 8, 2004 | 06:31 PM
Mud_Hunter's Avatar
Mud_Hunter
ok..pulled the motor and found cast #'s for the heads..I think "C8AE-H" sound correct?
Old May 8, 2004 | 06:38 PM
Ratsmoker's Avatar
Ratsmoker
That is a good head. Put CJ valves in it and port the exh. bowls a little and they perform great.
Old May 8, 2004 | 06:41 PM
Mud_Hunter's Avatar
Mud_Hunter
so....what is the final recommenadation on the cam ...the 801? with cj valves and some porting.
Old May 13, 2004 | 11:06 PM
Mud_Hunter's Avatar
Mud_Hunter
Ok ... Im down to ordering my cam. The 343801 seems pretty high on the rpm scale? Is there one that kicks in lower. I want a snappy, responsive, powerful engine. I dont care about econo here..just power. But want to keep my stock heads.
Old May 14, 2004 | 12:05 AM
d44hd's Avatar
d44hd
I have run the 941 in my 69 highboy....390 10.5 to 1..Shaved/ported heads...And was very impressed with the power...came on really strong in the midrange, and ran out about 5500 rpm....no problem on 91 octane fuel. Was really happy with it!
