Sponsored by: Real Truck
Installed aux backup lights
Old May 8, 2004 | 09:47 PM
Black88GT's Avatar
Black88GT
Cat_man, do you have any other pics of your rear end besides the gallery?
kw5413. do you have any pics of thes lights your talking about?
CWB, your setup is nice!
Old May 8, 2004 | 11:56 PM
cwb's Avatar
cwb
I bought a cheap pep boys model of light. Any 2" round light would work for what I did.
Old May 9, 2004 | 12:06 AM
Torque1st's Avatar
Torque1st
Posting Legend
Make sure you use some cold galvanizing compound on that bumper cut and then seal with paint or your bumper will start rusting and peel the chrome.
Always use a relay for powering aux lights. The backup switch in this case and other switches will not take the increased load.
Old May 9, 2004 | 12:18 AM
cwb's Avatar
cwb
Yup,what he said. I wired mine so I can turn it on when i want as well as in reverse. Great for campsites and tailgaters.
Old May 10, 2004 | 04:20 PM
maypo's Avatar
maypo
Broke one already.
It didn't take long. I busted one of the lights already. I was able to put it back together again. Maybe after a few more breaks I will move them to a safer area.
I had just washed and waxed (two coats of wax) the truck so I wanted it in the garage.... Backed in and hit the compressor. (Who is the damn fool who left it there?) What was that sound. I pulled up and voila, one broken and dangling fog light....
Old May 10, 2004 | 04:55 PM
jdadamsjr's Avatar
jdadamsjr
MAn - that WAS fast !!! didn't your backup sensors warn you ????
I've had mine outboard for almost two years !
Old May 11, 2004 | 09:08 AM
kw5413's Avatar
kw5413
Black88GT
Sorry for the late response but I have been out of town.
Go to JC Whitney web site. Go to Keyword and search for White Knight. You should find it there. Again...I love the lights so far and easy install.
Old May 11, 2004 | 12:21 PM
Pig Pen Jr's Avatar
Pig Pen Jr
Here are the ones I got from Pepboy's ($30)... both are 55watt and they light up the area back to the end of my 14' trailer. They are wired to the backup lights now, but as soon as I pick up a switch they are going to be hooked to that so I can use them when hooking the trailer up and such.
Old May 11, 2004 | 03:31 PM
KG7VL's Avatar
KG7VL
I've got a set of PIAA 1500 fog lights from my old truck that I am going to mount under the bumper. I added a 10 gauge wire from the engine compartment that is always hot (+12vdc, fused) to power a portable refrigerator in the bed of the truck. My plan is to use a single pole, double throw switch in the cab. Center is off, up will turn on rear fogs anytime, and down will allow them to switch on whenever I shift into reverse. I'll put a sealed relay behind the taillight and control it from the switch. I'll get the power for the lights from the 10 gauge wire. Mike
Old May 11, 2004 | 08:20 PM
99f350sd's Avatar
99f350sd
I'm looking for some about 3" lites for the rear bumper I just made. I want to flush mount them in this 200 lb monster...Anyone have any idea's I want to be able to back into anything and still have lights...
Old May 11, 2004 | 08:57 PM
cwb's Avatar
cwb
Maybe just cut grilles into it with a plasma?Pictures?
Old May 11, 2004 | 09:36 PM
maypo's Avatar
maypo
Hey Pig Pen Jr.
I like the place you mounted them.... I may move mine before the winter and my plowing in reverse kills them.....
Old May 12, 2004 | 07:01 AM
  #28
99f350sd's Avatar
99f350sd
Not water proof! I was thinking someone made lights that were flush mount but I can only find those whimpy cheap back up ones from grote...I need lotsa light for plowing...Pic's when I'm done 6x8 box 1/4 inch wall hit me baby
Old May 12, 2004 | 07:32 AM
  #29
Pig Pen Jr's Avatar
Pig Pen Jr
Originally Posted by maypo
Hey Pig Pen Jr.
They work real good there. They are attached to the hitch bar and are protected from road debris on all sides by either the hitch or the exhaust. I have them pushed way up right now, but when I tow I lower them about an inch so they shine under my trailer a little more. They would work fine where they are now, but i like to be able to see what is under the trailer a little when backing up and they still light the trailer up enough to help when I load my B2 in the dark. It only takes a Phillips screw driver and about 5 min to lower them.
I'm thinking of replacing them with the rubber coated ones we use on the farm trucks (9.99ea at Tractor Supply and you can get a trapezoid or spot style), just because the road salt and crap is already rusting the brackets after only one winter.
Old May 12, 2004 | 09:49 AM
  #30
airtractrdrivr's Avatar
airtractrdrivr
You guys that have the White Knight light setup, how are they holding up? I do alot of night hookups on my part time hauling job, and those sure look like the way to go.
