General Automotive Discussion
Transmission problems or clutch
Old May 4, 2004 | 02:53 PM
roberto378's Avatar
roberto378
help please
I just change the transmission - 5 speeds brand new – new clutch
I’m driving up to 35 miles / h and the car has no power it takes 10 minutes to go at 55 .
It has no power in any gear . I was trying every gear and the same problem
Before I change the transmission everything was ok
does anyone have any ideas?
Old May 4, 2004 | 03:00 PM
blu's Avatar
blu
Clutch is slipping?
85e150's Avatar
85e150
Does it rev easily when out of gear? Run normally out of gear from idle to high rpm? Vacuum leaks, plugged or badly dented exhaust, goofed up throttle linkage? Tranny not square on the motor--missing dowel pins? That would leave it in a bind all the time.
If your motor is running right and the tranny and drivetrain is this bound up, you are going to have a dramatic failure soon. Once you do the visuals, you will probably have to take it all apart again till you strike gold.
Good luck.
