turbo boost readings
Old May 17, 2002 | 12:31 PM
powerstroker250's Avatar
powerstroker250
Old May 20, 2002 | 01:01 PM
TRIMMAN98's Avatar
TRIMMAN98
what should turbo boost readings be at idle and while driving 70mph thanks
Old May 20, 2002 | 01:18 PM
Pass_On_Gas's Avatar
Pass_On_Gas
At idle: 0
At 70 mph on flat ground I run between 5 and 7 pounds
Old May 20, 2002 | 01:52 PM
newtruck's Avatar
newtruck
[updated:LAST EDITED ON 20-May-02 AT 02:56 PM (EST)]
When towing, flat land, no hills in the Keys, 60 mph, air temp 85,
in OD
exhaust temp = 750, Trans temp = 145, turbo = 9 psi, mpg = 12
not towing EGT 370 trans 120 turbo 5 mpg 22+
My ride is a 2000 F350 Super Duty, Lariat, PSD, 4X4, long bed with a cap, 4.1 rear, automatic, SRW, with added stainless steel 4" exhaust, turbo to 5" tip, with a "see thru" muffler and EGT, Trans temperature with turbo psi gauge. I tow a 12,000 pound 28.6 ft travel trailer
