Sponsored by: Auxito
rear brake problem
Old May 3, 2004 | 09:27 PM
chev402's Avatar
chev402
rear brake problem
2001 F150 7700 Intremittent Problem When Shifting Into Reverse. Truck Will Go About4feet Then Stop, Acts As If Brakes Are On
With The Brake Pedal Not Being Pushed. Shift Into Drive Then It Seems To Work Ok, Then Shift Back To Reverse Problem Still There. Drive Forward For A Couple Of Miles Then Ok. This Has Happened 4 Times
Any Suggestion Or Help
Thanks
Old May 3, 2004 | 09:41 PM
1979ford's Avatar
1979ford
Does the truck still move in reverse, or does it stop completly? It does sound like your brake shoes are binding up. I would take them off and see what they look like. Might be in need of some shoes and maybe turning your drums.
Old May 3, 2004 | 10:50 PM
chev402's Avatar
chev402
this truck has 4 wheel disc
Old May 3, 2004 | 11:59 PM
Racerguy's Avatar
Racerguy
Hi XXXX402
Ok,ok I guess I shouldn't bug you too much about the first part of your name
I would pull the rotors off the back and take a look at the park brakes. There is a drum inside the rotor and seperate brake shoes for the park brakes.
Lately I've seen quite a few become delaminated...the lining falls off the shoes.
If the lining got jammed up it could cause your problem.
Also take a look at the park brake lever inside the rear brakes to make sure it or the cable isnt hanging up.
Please let us know what you find.
Old May 4, 2004 | 02:05 AM
chev402's Avatar
chev402
check this out racerguy
thanks for the info.
name stands for my 67 chev c-10 streetrod with a 402 in it
all other vehicles are 2 explorers, 1 taurus , and the f150
i wouldn't be able to look at the rotors until sat.
thanks for the help
