Can a weak ignition module cause my 1979 f150 to run sluggish?
Ok, my 390 has been real sluggish on the bottom end last month or so. It started after i switched metering rods in my edelbrock 600. I put the old ones back in and changed the plugs but it is still sluggish. It seems bogged down but the carb is tuned. I guarantee its not running rich. It seems to be sluggish from idle to 2000 rpm. I have my timing at 12 btdc and 40 total. i have checked the engine vaccum and had 18. And i had 20 on vaccum advance. I have tryed my new Holley and the same thing happens. The dizzy and ignition module are less then a year old. The ignition module was some cheap brand piece. I want to believe its a timing thing but i am not sure what in specific is the cause. I have some dizzy springs for earlier advance but i didn't have the problem before so i have not used them. Tryed a new coil and that didn't help. I think its down to the module or dizzy.
Any suggestions?
You've got 20" Hg. at the advance at idle? (With 18 at the manifold?) If you've got the advance tied to manifold vac and your primary advance isn't mechanical than opening your throttle plates is going to drop your advance way back.
It would certainly bog then.
If the box was malfunctioning it would tend to sputter and miss throughout the range and it would probably get worse the higher the RPM.
Now you have a spare... Are you way out in the boonies or something? Around KC all of the major chain parts stores have test equipment. There is an entire test process listed in most repair manuals for the ignition system. Try running thru it.
When the engine is cold the thermostatic vacuum swicth applies manifold vacuum to the distributor. As soon as it warms up it applies ported (venturi) vacuum for normal running. If the engine overheats it applies manifold vacuum to the distributor.
i run ported vaccum but never have had the problem quite as bad before. I tryed manifold but didn't get the results i wanted. I might use use crane advance springs to bring the timing in quicker!
